跳转到主内容
简介
Use this guide to replace a defective Camera.
  1. Insert plastic opening tool under back cover.
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Insert plastic opening tool under battery.
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Insert plastic opening tool under back cover.
    • Pry the top cover upward to remove it from the phone.
  4. Remove the top cover.
    • Remove the top cover.
  5. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  6. Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly. Two screws from top and two screws from back.
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  7. Insert plastic opening tool under top cover. Using hand slide top cover away from phone. Using hand slide top cover away from phone.
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  8. Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  9. Insert plastic opening tool between back assembly and phone.
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  10. With plastic opening tool continue prying around the edge of the back assembly.
    • With plastic opening tool continue prying around the edge of the back assembly.
  11. Pull back panel assembly away from main body.
    • Pull back panel assembly away from main body.
  12. Use the flat end of a spudger to disconnect the camera assembly cable.
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  13. Remove camera from square housing. Remove camera from square housing.
    • Remove camera from square housing.
结论
另外一个人完成了本指南。
David R
于2015年07月20日注册
1,143 信誉积分
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 147
