当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Insert the spudger under each corner ribbon cable and lift them out of the way.
Use care when lifting the ribbon cables.
Insert a plastic pry tool into the gap between motherboard and base of phone
Tilt the motherboard up carefully.
Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
Use a spudger to pry the connector from the socket on the motherboard.
Lift motherboard from frame.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
