跳转到主内容
Samsung Exhibit II 4G Motherboard Replacement
你所需要的
  1. Samsung Exhibit II 4G Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Motherboard Replacement: 步骤 2 中的图像 1,1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Motherboard Replacement, Top Rear Housing Cover: 步骤 3 中的图像 1,1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung Exhibit II 4G Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Motherboard Replacement: 步骤 6 中的图像 1,3 Samsung Exhibit II 4G Motherboard Replacement: 步骤 6 中的图像 2,3 Samsung Exhibit II 4G Motherboard Replacement: 步骤 6 中的图像 3,3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Motherboard Replacement, Midframe: 步骤 7 中的图像 1,1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Motherboard Replacement: 步骤 8 中的图像 1,1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Motherboard Replacement: 步骤 9 中的图像 1,1
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Motherboard Replacement: 步骤 10 中的图像 1,1
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Motherboard Replacement, Vibration Motor: 步骤 11 中的图像 1,2 Samsung Exhibit II 4G Motherboard Replacement, Vibration Motor: 步骤 11 中的图像 2,2
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
  12. Samsung Exhibit II 4G Motherboard Replacement: 步骤 12 中的图像 1,2 Samsung Exhibit II 4G Motherboard Replacement: 步骤 12 中的图像 2,2
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
  13. Samsung Exhibit II 4G Motherboard Replacement, Rear Facing Camera: 步骤 13 中的图像 1,1
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  14. Samsung Exhibit II 4G Motherboard Replacement: 步骤 14 中的图像 1,2 Samsung Exhibit II 4G Motherboard Replacement: 步骤 14 中的图像 2,2
    • Remove camera from square housing.
  15. Samsung Exhibit II 4G Motherboard Replacement, Motherboard: 步骤 15 中的图像 1,3 Samsung Exhibit II 4G Motherboard Replacement, Motherboard: 步骤 15 中的图像 2,3 Samsung Exhibit II 4G Motherboard Replacement, Motherboard: 步骤 15 中的图像 3,3
    • Insert the spudger under each corner ribbon cable and lift them out of the way.
    • Use care when lifting the ribbon cables.
    • Insert a plastic pry tool into the gap between motherboard and base of phone
  16. Samsung Exhibit II 4G Motherboard Replacement: 步骤 16 中的图像 1,3 Samsung Exhibit II 4G Motherboard Replacement: 步骤 16 中的图像 2,3 Samsung Exhibit II 4G Motherboard Replacement: 步骤 16 中的图像 3,3
    • Tilt the motherboard up carefully.
    • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
    • Use a spudger to pry the connector from the socket on the motherboard.
    • Lift motherboard from frame.
结论
3等其他人完成本指南。
David R
于07/20/15注册
1,152 声望
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 621
