当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the back battery cover.
Using the Phillips #00 screwdriver, remove the phone's battery.
Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver
Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
Pull the antenna plug out of its socket.
Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
Pop the red hinged-release lever away from its ribbon. Then pull it out.
Peel the button sensor on the side of the motherboard off of the case.
Slightly pull up one side of the motherboard.
Pull the button/microphone plug out of its socket.
Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
You have successfully removed the motherboard from the phone.
取消:我没有完成这个指南。
与7其他贡献者
于04/20/11注册
11 声望
撰写一个指南
徽章: 5
+ 2更多徽章
CPSU-REGAN-S11S15G11
5 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 7
总计 2,310
