跳转到主内容
Samsung Eternity Motherboard Replacement
你所需要的
    • Remove the back battery cover.
  1. Samsung Eternity Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the phone's battery.
  2. Samsung Eternity Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver
  3. Samsung Eternity Motherboard Replacement: 步骤 4 中的图像 1,2 Samsung Eternity Motherboard Replacement: 步骤 4 中的图像 2,2
    • Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Motherboard Replacement: 步骤 6 中的图像 1,3 Samsung Eternity Motherboard Replacement: 步骤 6 中的图像 2,3 Samsung Eternity Motherboard Replacement: 步骤 6 中的图像 3,3
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Motherboard Replacement: 步骤 7 中的图像 1,1
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Motherboard Replacement: 步骤 8 中的图像 1,1
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Motherboard Replacement: 步骤 9 中的图像 1,3 Samsung Eternity Motherboard Replacement: 步骤 9 中的图像 2,3 Samsung Eternity Motherboard Replacement: 步骤 9 中的图像 3,3
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Motherboard Replacement: 步骤 10 中的图像 1,1
    • You have successfully removed the motherboard from the phone.
结论
Kevin Huang
于04/20/11注册
11 声望
撰写一个指南
团队
Cal Poly, Team 15-11, Regan Spring 2011 Cal Poly, Team 15-11, Regan Spring 2011 的会员
CPSU-REGAN-S11S15G11
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,304
