当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the back battery cover.
Using the Phillips #00 screwdriver, remove the phone's battery.
Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver
Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
Pop the antenna plug off of its socket with a pair of metal tweezers.
Peel off the Identification sticker.
Peel the button sensor on the side of the motherboard off of the case.
Pop the speaker plug out of its socket.
Pry the antennae/speaker component out of its casing. You need to use a little force to get the piece to pop out.
You will now be able to replace the antenna/speaker module.
取消:我没有完成这个指南。
2等其他人完成本指南。
与6其他贡献者
于04/20/11注册
70 声望
撰写一个指南
徽章: 9
+ 6更多徽章
CPSU-REGAN-S11S15G11
5 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,857
