跳转到主内容
加入维修社区 - 创建账户
Samsung Epix Motherboard Replacement
你所需要的
  1. Samsung Epix Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
    询问修复机器人
    添加评论
  2. Samsung Epix Motherboard Replacement: 步骤 2 中的图像 1,1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
    询问修复机器人
    添加评论
  3. Samsung Epix Motherboard Replacement, Speakers: 步骤 3 中的图像 1,1
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
    询问修复机器人
    添加评论
  4. Samsung Epix Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
    询问修复机器人
    添加评论
  5. Samsung Epix Motherboard Replacement: 步骤 5 中的图像 1,2 Samsung Epix Motherboard Replacement: 步骤 5 中的图像 2,2
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
    询问修复机器人
    添加评论
  6. Samsung Epix Motherboard Replacement: 步骤 6 中的图像 1,1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable in the bottom right corner of the motherboard.
    询问修复机器人
    添加评论
  7. Samsung Epix Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the circular battery from the plastic holder by inserting a 1 mm flat head screwdriver under the battery where the red and blue wires connect and lifting gently.
    • Make sure the battery is still connected to the motherboard via the red and blue wires. This part does not have to be completely removed.
    询问修复机器人
    添加评论
  8. Samsung Epix Motherboard Replacement: 步骤 8 中的图像 1,1
    • Using a Phillips #00 screwdriver, unscrew the two 3.5mm screws that connect the speaker to the motherboard.
    询问修复机器人
    添加评论
  9. Samsung Epix Motherboard Replacement: 步骤 9 中的图像 1,1
    • With the iPod opening tool, unclip the red and black wires connecting the speaker to the motherboard.
    • Lift the speaker off of the motherboard.
    • The camera will remain attached to the phone when removing the speaker.
    询问修复机器人
    添加评论
  10. Samsung Epix Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Using an iFixit opening tool, unlatch and disconnect the camera ribbon cable.
    询问修复机器人
    添加评论
  11. Samsung Epix Motherboard Replacement: 步骤 11 中的图像 1,1
    • Unlatch the LCD ribbon cable on the left side of the motherboard using the opening tool.
    询问修复机器人
    添加评论
  12. Samsung Epix Motherboard Replacement: 步骤 12 中的图像 1,2 Samsung Epix Motherboard Replacement: 步骤 12 中的图像 2,2
    • Unlatch and disconnect the two ribbon cables at the bottom center of the motherboard.
    • The two disconnected ribbon cables connect to the keypad and center button.
    询问修复机器人
    添加评论
  13. Samsung Epix Motherboard Replacement: 步骤 13 中的图像 1,1
    • Unlatch and remove the front panel ribbon cable located at the bottom right of the motherboard.
    询问修复机器人
    添加评论
  14. Samsung Epix Motherboard Replacement: 步骤 14 中的图像 1,1
    • Use the opening tool to gently disconnect the microphone cable, also located at the bottom right of the motherboard.
    询问修复机器人
    添加评论
  15. Samsung Epix Motherboard Replacement: 步骤 15 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the 3.5 mm screw at the bottom center of the motherboard.
    询问修复机器人
    添加评论
  16. Samsung Epix Motherboard Replacement: 步骤 16 中的图像 1,1
    • Carefully lift the motherboard from the left side to begin removing it from the phone chassis.
    • A ribbon cable is still connected underneath on the right side.
    询问修复机器人
    添加评论
  17. Samsung Epix Motherboard Replacement: 步骤 17 中的图像 1,1
    • Flip the motherboard slightly to access the back, then use the opening tool to unlatch and disconnect the remaining ribbon cable.
    • Remove the motherboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Mark Wyse
于04/19/11注册
62 声望
创作了2篇指南
团队
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 的会员
CPSU-REGAN-S11S15G15
5 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 42
总计 1,979
