跳转到主内容
Samsung Epix Keyboard Replacement
你所需要的
  1. Samsung Epix Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix Keyboard Replacement: 步骤 2 中的图像 1,1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
  4. Samsung Epix Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
  5. Samsung Epix Keyboard Replacement: 步骤 5 中的图像 1,2 Samsung Epix Keyboard Replacement: 步骤 5 中的图像 2,2
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix Keyboard Replacement: 步骤 6 中的图像 1,1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable located in the bottom right side of the motherboard.
  7. Samsung Epix Keyboard Replacement: 步骤 7 中的图像 1,1
    • Using an iPod opening tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully remove the ribbon.
  8. Samsung Epix Keyboard Replacement: 步骤 8 中的图像 1,1
    • Remove the front faceplate.
  9. Samsung Epix Keyboard Replacement: 步骤 9 中的图像 1,1
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove.
结论
另外一个人完成了本指南。
Chris
于04/20/11注册
23 声望
撰写一个指南
团队
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 的会员
CPSU-REGAN-S11S15G15
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,646
