跳转到主内容
Samsung Epic 4G Touch microSD Card Replacement
你所需要的
  1. Samsung Epic 4G Touch microSD Card Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Epic 4G Touch microSD Card Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch microSD Card Replacement: 步骤 2 中的图像 1,2 Samsung Epic 4G Touch microSD Card Replacement: 步骤 2 中的图像 2,2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch microSD Card Replacement, microSD Card: 步骤 3 中的图像 1,2 Samsung Epic 4G Touch microSD Card Replacement, microSD Card: 步骤 3 中的图像 2,2
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch microSD Card Replacement: 步骤 4 中的图像 1,1
    • Pull the microSD card away from its slot.
结论
3等其他人完成本指南。
2条评论
Uhh.... my Australian SGSII looks different to this...
Bonj - 回复
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 4,356
