跳转到主内容
Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement
你所需要的
  1. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 2 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 2 中的图像 2,2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, microSD Card: 步骤 3 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, microSD Card: 步骤 3 中的图像 2,2
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • During reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 4 中的图像 1,1
    • Pull the microSD card away from its slot.
  5. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Battery: 步骤 5 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Battery: 步骤 5 中的图像 2,2
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
  6. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 6 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 6 中的图像 2,2
    • Lift and remove the battery from the midframe.
  7. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Plastic Midframe: 步骤 7 中的图像 1,1
    • Remove the six 4.0 mm Phillips #00 screws securing the midframe to the front panel assembly.
  8. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 8 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 8 中的图像 2,2
    • Unless you pry at the right insertion points, you might have a difficult time removing the midframe. This shot of the display assembly, with display glass facing down, is meant to help you locate them.
    • The first insertion point is a divot to the left of the micro-USB port.
    • The second insertion point is a divot to the right of the micro-USB port near the corner of the phone.
    • The final insertion point is located about two inches to the right of the volume control toggle, toward the corner of the phone. An additional insertion point is located slightly to the right of the volume button if you need it.
  9. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 9 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 9 中的图像 2,2
    • Insert a plastic opening tool slightly to the left of the micro-USB port, and pry between the midframe and the display to open a gap.
  10. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 10 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 10 中的图像 2,2
    • Wedge a plastic opening tool slightly to the right of the micro-USB port, and pry between the midframe and the display to widen the gap.
  11. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 11 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 11 中的图像 2,2
    • Pry again about two inches to the right of the volume control toggles between the midframe and the front panel assembly.
  12. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 12 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 12 中的图像 2,2
    • Pull the micro-USB end of the front panel assembly out and away from the midframe and lift up to free it entirely.
  13. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Motherboard Connectors: 步骤 13 中的图像 1,1
    • Headphone jack/vibrator assembly cable connector
    • Front-facing camera cable connector
    • Digitizer cable connector
    • Display cable connector
  14. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Headphone Jack/Vibrator Connector: 步骤 14 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Headphone Jack/Vibrator Connector: 步骤 14 中的图像 2,2
    • Use the flat end of a spudger to disconnect the headphone jack/vibrator assembly cable.
  15. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Motherboard Assembly: 步骤 15 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Motherboard Assembly: 步骤 15 中的图像 2,2
    • Use the flat end of a spudger to disconnect the front-facing camera cable connector.
  16. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 16 中的图像 1,1
    • Carefully disconnect the digitizer display cable.
  17. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 17 中的图像 1,1
    • Use a spudger to disconnect the display cable connector.
  18. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 18 中的图像 1,1
    • Remove the two 3 mm Phillips #00 screws.
  19. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 19 中的图像 1,3 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 19 中的图像 2,3 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 19 中的图像 3,3
    • Lift the micro-USB end of the motherboard away from the display assembly and pull it down.
    • Be mindful that you don't snag the motherboard on any cables as you remove it.
  20. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement, Front Facing Camera/Earpiece Speaker Assembly: 步骤 20 中的图像 1,1
    • Remove the 2.3 mm Phillips #00 screw securing the front-facing camera bracket to the display assembly.
  21. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 21 中的图像 1,1
    • Remove the front-facing camera bracket from the display assembly.
  22. Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 22 中的图像 1,2 Samsung Epic 4G Touch Front Facing Camera/Earpiece Speaker Assembly Replacement: 步骤 22 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using a pair of tweezers, or your fingers, remove the front-facing camera/earpiece speaker assembly.
结论
8等其他人完成本指南。
一条评论
This Repar is NOT for the earpiece speaker. It is for the camera only. The earpiece speaker for the i9100 is attached to the vibrator and headphone jack cable.
tylerdeer - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 9,186
