跳转到主内容
Samsung Epic 4G Touch Battery Replacement
你所需要的
  1. Samsung Epic 4G Touch Battery Replacement, Rear Case: 步骤 1 中的图像 1,2 Samsung Epic 4G Touch Battery Replacement, Rear Case: 步骤 1 中的图像 2,2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch Battery Replacement: 步骤 2 中的图像 1,2 Samsung Epic 4G Touch Battery Replacement: 步骤 2 中的图像 2,2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch Battery Replacement, Battery: 步骤 3 中的图像 1,2 Samsung Epic 4G Touch Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
  4. Samsung Epic 4G Touch Battery Replacement: 步骤 4 中的图像 1,2 Samsung Epic 4G Touch Battery Replacement: 步骤 4 中的图像 2,2
    • Lift and remove the battery from the midframe.
结论
10等其他人完成本指南。
2条评论
i just reacently got my phone and I don't know whats happening to it. it keeps turning itself off. iv factory reset it 2 times. should I replace the phone or just the battery. I have a Samsung galaxy s II. (sprint)
gamerzzz - 回复
I have an samsung galaxy s2 gsm unlocked and my battery wont stay charge and sometimes when its plugged in a charger it decreases instead of increasing and if it does charges it decrease fast what shall i do shall i get a new battery or replace the phone
ianasims - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 9,701
