当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Slide your fingernail along the edge of the device and pull at the plastic backing.
While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
While separating the two components, most of the buttons (including the power button) will fall out.
Remove the power button using tweezers if it did not fall out in the previous step.
At this point, you can replace the power button with a new one from a manufacturer.
Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
Do not rip the white cables out of the device.
Lift and remove the motherboard from the device.
The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
