Slide your fingernail along the edge of the device and pull at the plastic backing.
While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
While separating the two components, most of the buttons (including the power button) will fall out.
Remove the power button using tweezers if it did not fall out in the previous step.
At this point, you can replace the power button with a new one from a manufacturer.
Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
Do not rip the white cables out of the device.
Lift and remove the motherboard from the device.
The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
Remove the white label sticker.
Remove the four screws on the left side of the device with a small Phillips screwdriver.
Two of the screws are found behind the white label, and two are found directly above the label.
Lift up and loosen the metallic silver trim on the perimeter of the phone using a nylon spudger.
Carefully remove the gray mid-plate with the spudger.
Take extra caution to not destroy the QWERTY keyboard, which lies directly behind the mid-plate. Do not slide open the phone at this time.
The mid-plate should be completely removed from the keyboard and separated from the device.
At this point, you may remove the original QWERTY keyboard and install a replacement keyboard. Installation is the reverse of removal.
嵌入本指南
选择尺寸并复制下面的代码嵌入本指南,为你网站/论坛的一个小插件。
预览
