跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Samsung Epic 4G Battery Replacement
你所需要的
  1. Samsung Epic 4G Battery Replacement, Phone Case: 步骤 1 中的图像 1,1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Battery Replacement: 步骤 2 中的图像 1,1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Remove the battery from the device by pulling the battery edge upwards.
结论
4等其他人完成本指南。
团队
Cal Poly, Team 24-25, Regan Fall 2012 Cal Poly, Team 24-25, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G25
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 2,048
