跳转到主内容
Samsung Droid Charge SIM Card Port Replacement
你所需要的
  1. Samsung Droid Charge SIM Card Port Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
  2. Samsung Droid Charge SIM Card Port Replacement, Battery: 步骤 2 中的图像 1,1
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
  3. Samsung Droid Charge SIM Card Port Replacement, microSD: 步骤 3 中的图像 1,1
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
  4. Samsung Droid Charge SIM Card Port Replacement, SIM Card: 步骤 4 中的图像 1,1
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
  5. Samsung Droid Charge SIM Card Port Replacement, SIM Card Port: 步骤 5 中的图像 1,1
    • Carefully remove the back cover.
    • Remove the two 5mm screws with a small Phillips head screwdriver.
  6. Samsung Droid Charge SIM Card Port Replacement: 步骤 6 中的图像 1,1
    • Removal of the back half of the casing.
    • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
    • Use a prying motion to lift the casing up. This will separate the phone casing.
    • Repeat this motion all around the screen edge until the casing pops off.
  7. Samsung Droid Charge SIM Card Port Replacement: 步骤 7 中的图像 1,1
    • Release the volume button flex cable on the right.
    • Release the pop connector on the motherboard located to the left of the SIM card port.
  8. Samsung Droid Charge SIM Card Port Replacement: 步骤 8 中的图像 1,2 Samsung Droid Charge SIM Card Port Replacement: 步骤 8 中的图像 2,2
    • Your SIM card port is now unattached.
    • Remove SIM card port from motherboard.
结论
3等其他人完成本指南。
Lucas Carter
于09/27/12注册
172 声望
撰写一个指南
团队
Cal Poly, Team 15-44, Forte Fall 2012 Cal Poly, Team 15-44, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G44
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 2,394
