跳转到主内容
Samsung Droid Charge Battery Replacement
你所需要的
  1. Samsung Droid Charge Battery Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
  2. Samsung Droid Charge Battery Replacement, Battery: 步骤 2 中的图像 1,1
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
结论
5等其他人完成本指南。
Luke Gordon
于09/26/12注册
178 声望
创作了5篇指南
团队
Cal Poly, Team 15-44, Forte Fall 2012 Cal Poly, Team 15-44, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G44
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 33
总计 1,687
