当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Locate the white clip that attaches the cord to the motherboard
Grasp clip and squeeze to release
Lift up and remove power cord
Slide cord mount from outer case
In order to remove the tray motor you must detach the small rubber band that runs between the two shown wheels.
If the rubber band is improperly fitted onto one of the wheels or broken this is probably the cause of the tray not opening or closing.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
