当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Open the tray by pressing the eject button
Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
Press the eject button to insert the tray
After the tray is closed unplug DVD player
Unscrew the 3 screws in the back.
Pull the outer case upward and then towards you.
There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
Locate the white clip that attaches the cord to the motherboard
Grasp clip and squeeze to release
Lift up and remove power cord
Slide cord mount from outer case
取消:我没有完成这个指南。
2等其他人完成本指南。
与8其他贡献者
于01/28/11注册
410 声望
创作了3篇指南
徽章: 10
+ 7更多徽章
CPSU-REGAN-W11S3G30
4 名成员
创作了8篇指南
where can I get a replacement cord?
Bill Cavanaugh - 2015年11月19日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 11
总计 3,165
