跳转到主内容
Samsung DVD-HD850 Player Rubber Band Replacement
你所需要的
  1. Samsung DVD-HD850 Player Rubber Band Replacement, Cover: 步骤 1 中的图像 1,1
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Rubber Band Replacement, Locate and remove screws: 步骤 2 中的图像 1,1
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Rubber Band Replacement, Remove Cover: 步骤 3 中的图像 1,1
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
  4. Samsung DVD-HD850 Player Rubber Band Replacement, Locate and Remove The Disk Tray: 步骤 4 中的图像 1,1
    • *NOTE* remember to never connect to power when working on electrical components
    • Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
  5. Samsung DVD-HD850 Player Rubber Band Replacement, Removing The Data Strips: 步骤 5 中的图像 1,1
    • Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
  6. Samsung DVD-HD850 Player Rubber Band Replacement, Removing The Screws: 步骤 6 中的图像 1,3 Samsung DVD-HD850 Player Rubber Band Replacement, Removing The Screws: 步骤 6 中的图像 2,3 Samsung DVD-HD850 Player Rubber Band Replacement, Removing The Screws: 步骤 6 中的图像 3,3
    • As noted by the red circles, locate and remove the screws one at a time
  7. Samsung DVD-HD850 Player Rubber Band Replacement, Disk Tray Removal: 步骤 7 中的图像 1,1
    • After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
    • Be careful not to push too much pressure on the brackets since they tend to break easily
  8. Samsung DVD-HD850 Player Rubber Band Replacement, Success!: 步骤 8 中的图像 1,1
    • Congrats! You have sucessfully have taken out the disk drive
  9. Samsung DVD-HD850 Player Rubber Band Replacement, Disk Tray Preparation: 步骤 9 中的图像 1,1
    • remember to never connect the device to a power source when working on electrical components on/in the device
    • It it recommended to buy the Elastic Rubber Band needed for this repair guide first, you can buy the band at this link: http://www.ebay.com/itm/100-Latex-Elasti... the name of the specific rubber band for this device is located at the top of this repair guide
  10. Samsung DVD-HD850 Player Rubber Band Replacement, Locate the White Spindle: 步骤 10 中的图像 1,1
    • Locate the small white spindle on the face of the tray (the face is where the DVD name is edged on the front) and turn the spindle counterclockwise (with the screw driver listed under "tools" or something similar) until the tray begins to open
  11. Samsung DVD-HD850 Player Rubber Band Replacement, Opening The Disk Tray: 步骤 11 中的图像 1,2 Samsung DVD-HD850 Player Rubber Band Replacement, Opening The Disk Tray: 步骤 11 中的图像 2,2
    • Once the tray is opened, locate the rubber band, as noted by the blue box, and remove and replace it by pulling it out of the mechanism
  12. Samsung DVD-HD850 Player Rubber Band Replacement, Rubber Band Replacement: 步骤 12 中的图像 1,2 Samsung DVD-HD850 Player Rubber Band Replacement, Rubber Band Replacement: 步骤 12 中的图像 2,2
    • Once removed, replace the band with one you have bought, or have on-hand and and insert it into its rightful place
结论
Carlos
于10/16/14注册
354 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-6, Duarte Fall 2014 UMass Dartmouth, Team 1-6, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 25
总计 751
