跳转到主内容
Samsung DVD-HD850 Player Power Cord Replacement
你所需要的
  1. Samsung DVD-HD850 Player Power Cord Replacement, Cover: 步骤 1 中的图像 1,1
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Power Cord Replacement, Locate and remove screws: 步骤 2 中的图像 1,1
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Power Cord Replacement, Remove Cover: 步骤 3 中的图像 1,1
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
  4. Samsung DVD-HD850 Player Power Cord Replacement, Replacing the power cord: 步骤 4 中的图像 1,2 Samsung DVD-HD850 Player Power Cord Replacement, Replacing the power cord: 步骤 4 中的图像 2,2
    • Unclip the old power cord from the dual pin connector.
    • Once the old power cord has been unclipped take the new power cord and simply clip it in where the old one was.
  5. Samsung DVD-HD850 Player Power Cord Replacement, Adjust the wire: 步骤 5 中的图像 1,2 Samsung DVD-HD850 Player Power Cord Replacement, Adjust the wire: 步骤 5 中的图像 2,2
    • Adjust the rubber block on the power cord so that it fits in the slot on the back of the DVD player.
    • This makes it so that the cover panel will be able to slide back on.
结论
Robert Moss
于10/22/14注册
201 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-6, Duarte Fall 2014 UMass Dartmouth, Team 1-6, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 12
总计 464
