跳转到主内容
Samsung DVD-HD850 Player Disk Tray Replacement
你所需要的
  1. Samsung DVD-HD850 Player Disk Tray Replacement, Locate and Remove The Disk Tray: 步骤 1 中的图像 1,1
    • *NOTE* remember to never connect to power when working on electrical components
    • Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
  2. Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Data Strips: 步骤 2 中的图像 1,1
    • Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
  3. Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: 步骤 3 中的图像 1,3 Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: 步骤 3 中的图像 2,3 Samsung DVD-HD850 Player Disk Tray Replacement, Removing The Screws: 步骤 3 中的图像 3,3
    • As noted by the red circles, locate and remove the screws one at a time
  4. Samsung DVD-HD850 Player Disk Tray Replacement, Disk Tray Removal: 步骤 4 中的图像 1,1
    • After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
    • Be careful not to push too much pressure on the brackets since they tend to break easily
  5. Samsung DVD-HD850 Player Disk Tray Replacement, Success!: 步骤 5 中的图像 1,1
    • Congrats! You have sucessfully have taken out the disk drive
结论
另外一个人完成了本指南。
Carlos
于10/16/14注册
354 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-6, Duarte Fall 2014 UMass Dartmouth, Team 1-6, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 20
总计 636
