跳转到主内容
Samsung DVD-HD850 Player Cover Replacement
你所需要的
  1. Samsung DVD-HD850 Player Cover Replacement, Cover: 步骤 1 中的图像 1,1
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Cover Replacement, Locate and remove screws: 步骤 2 中的图像 1,1
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Cover Replacement, Remove Cover: 步骤 3 中的图像 1,1
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
结论
另外一个人完成了本指南。
Devon Clements
于10/21/14注册
228 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-6, Duarte Fall 2014 UMass Dartmouth, Team 1-6, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G6
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 13
总计 428
