跳转到主内容
Samsung DV300F Front LCD Screen Replacement
你所需要的
  1. Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: 步骤 1 中的图像 1,3 Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: 步骤 1 中的图像 2,3 Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: 步骤 1 中的图像 3,3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Front LCD Screen Replacement: 步骤 2 中的图像 1,2 Samsung DV300F Front LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Front LCD Screen Replacement: 步骤 3 中的图像 1,3 Samsung DV300F Front LCD Screen Replacement: 步骤 3 中的图像 2,3 Samsung DV300F Front LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Front LCD Screen Replacement, Back Button Control: 步骤 4 中的图像 1,2 Samsung DV300F Front LCD Screen Replacement, Back Button Control: 步骤 4 中的图像 2,2
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
  5. Samsung DV300F Front LCD Screen Replacement, Back LCD Screen: 步骤 5 中的图像 1,1
    • Remove the back LCD screen from its place carefully.
  6. Samsung DV300F Front LCD Screen Replacement: 步骤 6 中的图像 1,2 Samsung DV300F Front LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
  7. Samsung DV300F Front LCD Screen Replacement, Front LCD Screen: 步骤 7 中的图像 1,2 Samsung DV300F Front LCD Screen Replacement, Front LCD Screen: 步骤 7 中的图像 2,2
    • Unscrew the 3 silver 4.5 mm screws from the circuit board using a Phillips #0 screwdriver.
    • Remove the circuit board cover.
  8. Samsung DV300F Front LCD Screen Replacement: 步骤 8 中的图像 1,3 Samsung DV300F Front LCD Screen Replacement: 步骤 8 中的图像 2,3 Samsung DV300F Front LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Flip the black tab where the front LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the front LCD screen from the circuit board.
    • You can do this easily with your fingers.
    • Remove the front LCD screen from the front of the camera.
结论
另外一个人完成了本指南。
Timothy Gordon
于03/23/15注册
841 声望
创作了5篇指南
团队
Baylor, Team 5-10, Williams Spring 2015 Baylor, Team 5-10, Williams Spring 2015 的会员
BU-WILLIAMS-S15S5G10
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 28
总计 1,115
