跳转到主内容
Samsung DV180F Repair Display Screen Replacement
你所需要的
  1. Samsung DV180F Repair Display Screen Replacement, Display Screen: 步骤 1 中的图像 1,3 Samsung DV180F Repair Display Screen Replacement, Display Screen: 步骤 1 中的图像 2,3 Samsung DV180F Repair Display Screen Replacement, Display Screen: 步骤 1 中的图像 3,3
    • Use a pry tool to push the highlighted blue latch away from the battery in the direction of the arrow. Remove the battery.
    • Use the Phillips 000 Bit to remove all screws from the perimeter of the device. Set aside.
    • Use a small Plastic Opening Tool at the seam by the Micro USB plug. Separate the plastic case from the device.
  2. Samsung DV180F Repair Display Screen Replacement: 步骤 2 中的图像 1,2 Samsung DV180F Repair Display Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the outer casing holding the back part of the camera together. Leave on the front casing.
    • Use a Phillips screwdriver to remove the two small screws holding the outer casing to the mother board.
    • Use the prying tool to unhook the casing from the plate covering the motherboard
  3. Samsung DV180F Repair Display Screen Replacement: 步骤 3 中的图像 1,3 Samsung DV180F Repair Display Screen Replacement: 步骤 3 中的图像 2,3 Samsung DV180F Repair Display Screen Replacement: 步骤 3 中的图像 3,3
    • Release the ribbon from the button casing connected to the motherboard.
    • Hold the metal casing out of the way and snap the ribbon connector back. Remove the display screen ribbon attached.
    • Replace the screen then repeat all of these steps in reverse order to reassemble.
结论
3等其他人完成本指南。
团队
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S14G4
4 名成员
创作了8篇指南
2指南评论
I got it open in the hope of finding a screen ID. I can not find a replacement screen for the DV180F. do you know if the DV150 screen will work?
lrrpbill68 - 回复
im looking for a screen as well were you able to find a replacement?
Sidath Paranavithane -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 23
总计 631
