跳转到主内容
Samsung DV180F Repair Battery Replacement
你所需要的
  1. Samsung DV180F Repair Battery Replacement, Battery: 步骤 1 中的图像 1,2 Samsung DV180F Repair Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery door and slide it to the right to unlatch it. Swing the battery door up to expose the battery chamber.
    • Ensure that the camera is turned off before attempting to replace the battery.
  2. Samsung DV180F Repair Battery Replacement: 步骤 2 中的图像 1,1
    • Locate the blue latch that holds the battery in the battery chamber. Using your fingernail or a plastic opening tool, push it away from the battery, in the direction of the arrow on the latch.
  3. Samsung DV180F Repair Battery Replacement: 步骤 3 中的图像 1,2 Samsung DV180F Repair Battery Replacement: 步骤 3 中的图像 2,2
    • Once the latch is disengaged, the battery should pop up. Grab the battery and slide it up and out of the camera.
  4. Samsung DV180F Repair Battery Replacement: 步骤 4 中的图像 1,1
    • Move the blue latch out of the way and slide the replacement battery into the battery chamber. Lightly push until the battery clicks in place. Close the battery door.
    • Make sure that the replacement battery is oriented correctly.
结论
maria
于09/26/16注册
250 声望
创作了2篇指南
团队
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S14G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 466
