跳转到主内容
Samsung DV180F Repair Back control buttons Replacement
你所需要的
  1. Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: 步骤 1 中的图像 1,2 Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: 步骤 1 中的图像 2,2
    • Ensure the camera is turned off and battery is taken out before you begin.
    • Remove the two external screws from the camera using a Phillips 000 screwdriver.
  2. Samsung DV180F Repair Back control buttons Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic opening tool in the gap between the camera body and back panel.
    • Pry along the right side of the camera to separate the back panel.
  3. Samsung DV180F Repair Back control buttons Replacement: 步骤 3 中的图像 1,1
    • Once the camera is open, remove the two internal screws using a Phillips 000 screwdriver.
  4. Samsung DV180F Repair Back control buttons Replacement: 步骤 4 中的图像 1,2 Samsung DV180F Repair Back control buttons Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to release the lock securing the ribbon receptor to the right side of the motherboard.
    • Ribbons have to be unlocked before removal to prevent damage.
  5. Samsung DV180F Repair Back control buttons Replacement: 步骤 5 中的图像 1,1
    • Gently lift the circuit board from the camera.
    • Remove the display ribbon receptor lock to remove back panel from the motherboard.
  6. Samsung DV180F Repair Back control buttons Replacement: 步骤 6 中的图像 1,2 Samsung DV180F Repair Back control buttons Replacement: 步骤 6 中的图像 2,2
    • Remove back display.
    • Replace the back button panel.
结论
maria
于09/26/16注册
250 声望
创作了2篇指南
团队
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S14G4
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 466
