简介
In this guide, I will show you how to replace the hard drive in a Samsung All-in-One Desktop DP515A2G.
你所需要的
Put the Samsung dp515a2g face down on a surface that will not scratch the monitor.
在这个步骤中使用的工具:iFixit Opening Picks (Set of 6)$4.99
Gently insert an opening pick in the seam between the back panel and bezel.
Run the opening pick along the seam, carefully freeing the clips holding the back panel in place.
The back panel should come away without resistance.
在这个步骤中使用的工具:Phillips #000 Screwdriver$5.49
Remove the 3 screws highlighted in red with a 000 Screwdriver
Using the 000 Screwdriver remove the screw on each side.
The hard drive should pull free of the shroud.
4等其他人完成本指南。
