跳转到主内容
Samsung Core Prime Screen Replacement
你所需要的
    • Before starting this repair. Be sure to remove any protective cases or screen covers.
    • Unscrew the two screws at the bottom of the phone.
    • Carefully use a pry tool to pry the edge of your screen.
    • Lift the screen about 90 degrees and you can see the yellow bezel cable.
    • Then unplug it and totally replace your screen.
结论
5等其他人完成本指南。
Khanhtruong Nguyen
于03/24/22注册
139 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 43
总计 718
