跳转到主内容
Samsung Chromebook series 5 XE550C22 SSD Replacement
你所需要的
  1. Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 步骤 1 中的图像 1,3 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 步骤 1 中的图像 2,3 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 2 中的图像 1,2 Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 2 中的图像 2,2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 3 中的图像 1,3 Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 3 中的图像 2,3 Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 3 中的图像 3,3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 4 中的图像 1,2 Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 4 中的图像 2,2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: 步骤 5 中的图像 1,2 Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 6 中的图像 1,2 Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 6 中的图像 2,2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook series 5 XE550C22 SSD Replacement, SSD: 步骤 7 中的图像 1,1
    • Locate the SSD in the center of the Chromebook.
  8. Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 8 中的图像 1,3 Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 8 中的图像 2,3 Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 8 中的图像 3,3
    • Remove the single 3.5mm screw using the J0 screwdriver.
    • The SSD should "pop-up" on its own after it's unscrewed.
  9. Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 9 中的图像 1,2 Samsung Chromebook series 5 XE550C22 SSD Replacement: 步骤 9 中的图像 2,2
    • Pull the SSD up and away from the Chromebook
结论
4等其他人完成本指南。
Abel Osorio
于09/11/17注册
330 声望
创作了2篇指南
团队
CSU Fullerton, Team S2-G7, Bruce Fall 2017 CSU Fullerton, Team S2-G7, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S2G7
3 名成员
创作了14篇指南
4条评论
Hello where can I get I higher SSD to buy
aduboa moses - 回复
The SSD on the Chromebook 3 is non-upgradable. This is a different model. Please post this guide in the model you have.
frontiergds - 回复
If you want to get more storage out of your chromebook get a sd card and you will only need it if you have a chrultrabook.
Will F - 回复
The samsung chromebook shown on this guide is Samsung Chromebook XE550C22. The samsung chromebook 3 ( XE500C13 ), is totally different model. I have edited the title and description to match the actual model.
coldspring21 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 41
总计 5,094
