跳转到主内容
Samsung Chromebook XE550C22 RAM Replacement
你所需要的
  1. Samsung Chromebook XE550C22 RAM Replacement, Back Panel: 步骤 1 中的图像 1,3 Samsung Chromebook XE550C22 RAM Replacement, Back Panel: 步骤 1 中的图像 2,3 Samsung Chromebook XE550C22 RAM Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 RAM Replacement: 步骤 2 中的图像 1,2 Samsung Chromebook XE550C22 RAM Replacement: 步骤 2 中的图像 2,2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 RAM Replacement: 步骤 3 中的图像 1,3 Samsung Chromebook XE550C22 RAM Replacement: 步骤 3 中的图像 2,3 Samsung Chromebook XE550C22 RAM Replacement: 步骤 3 中的图像 3,3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 RAM Replacement: 步骤 4 中的图像 1,2 Samsung Chromebook XE550C22 RAM Replacement: 步骤 4 中的图像 2,2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 RAM Replacement, Battery: 步骤 5 中的图像 1,2 Samsung Chromebook XE550C22 RAM Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 RAM Replacement: 步骤 6 中的图像 1,2 Samsung Chromebook XE550C22 RAM Replacement: 步骤 6 中的图像 2,2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 RAM Replacement, RAM: 步骤 7 中的图像 1,1
    • Locate the RAM on the middle right side of the Chromebook.
  8. Samsung Chromebook XE550C22 RAM Replacement: 步骤 8 中的图像 1,2 Samsung Chromebook XE550C22 RAM Replacement: 步骤 8 中的图像 2,2
    • Using your fingers, separate the silver clips that are holding the RAM in place on each side.
    • The RAM will "pop-up" on its own after separating clips.
  9. Samsung Chromebook XE550C22 RAM Replacement: 步骤 9 中的图像 1,2 Samsung Chromebook XE550C22 RAM Replacement: 步骤 9 中的图像 2,2
    • Pull the RAM away from the Chromebook.
结论
2等其他人完成本指南。
Abel Osorio
于09/11/17注册
330 声望
创作了2篇指南
团队
CSU Fullerton, Team S2-G7, Bruce Fall 2017 CSU Fullerton, Team S2-G7, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S2G7
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 13
总计 687
