简介
After a period of time, the device might run too hot, this guide will help to clean up or replace the cooling fan for the Samsung Chromebook XE550C22.
你所需要的
Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
在这个步骤中使用的工具:Tweezers$3.99
Rotate the Chromebook 180 degrees so the fan is closest to you, and locate the fan power cable.
Disconnect the fan cable from the motherboard with the angled tweezers.
另外一个人完成了本指南。
