跳转到主内容
Samsung Chromebook XE500C21-A03US RAM Replacement
你所需要的
  1. Samsung Chromebook XE500C21-A03US RAM Replacement, Back Cover: 步骤 1 中的图像 1,3 Samsung Chromebook XE500C21-A03US RAM Replacement, Back Cover: 步骤 1 中的图像 2,3 Samsung Chromebook XE500C21-A03US RAM Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Turn the power off before beginning this step.
    • Most Chromebooks contain rubber circle pads on each of the four corners to cover the screws. In order to remove the rubber pads, simply use any opening tool.
    • Lay the Chromebook down so that the bottom cover is facing upward.
    • Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
  2. Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 2 中的图像 1,3 Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 2 中的图像 2,3 Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 2 中的图像 3,3
    • Place the opening tool in the divot between the spine of the Chromebook and the back cover.
    • Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
  3. Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 3 中的图像 1,2 Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 3 中的图像 2,2
    • Using the opening tool, pry off the back cover of the Chromebook
    • Be gentle while prying to avoid breaking the back cover.
  4. Samsung Chromebook XE500C21-A03US RAM Replacement, Battery: 步骤 4 中的图像 1,2 Samsung Chromebook XE500C21-A03US RAM Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  5. Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 5 中的图像 1,2 Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 5 中的图像 2,2
    • Carefully lift the top of the battery then pull it away from you to remove it.
    • Some batteries may be attached via a battery connector. Disconnect the battery connector by simply pulling straight up at its base.
  6. Samsung Chromebook XE500C21-A03US RAM Replacement, RAM: 步骤 6 中的图像 1,2 Samsung Chromebook XE500C21-A03US RAM Replacement, RAM: 步骤 6 中的图像 2,2
    • Use a blunt precision tweezer to remove the speaker cord from the RAM
  7. Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 7 中的图像 1,2 Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 7 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove all six 2.5 mm screws .
    • Start removing the screws from the wifi card.
  8. Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 8 中的图像 1,2 Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 8 中的图像 2,2
    • Gently lift the bottom of the wifi card then pull it towards you to disconnect it from the socket.
    • Our Chromebook does not have a circuit board. Remove all units connected to the circuit board if necessary.
  9. Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 9 中的图像 1,3 Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 9 中的图像 2,3 Samsung Chromebook XE500C21-A03US RAM Replacement: 步骤 9 中的图像 3,3
    • Gently lift the top left corner of the RAM and pull upward to remove it from the Chromebook.
结论
2等其他人完成本指南。
huy
于09/11/17注册
337 声望
创作了3篇指南
团队
CSU Fullerton, Team S2-G5, Bruce Fall 2017 CSU Fullerton, Team S2-G5, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S2G5
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 900
