简介
A fast and simple guide to replace the keyboard to your Chromebook.
你所需要的
Lay the Chromebook down so that the bottom cover is facing upward.
Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
Using a blunt precision tweezer, pull the white wire off the wificard.
Repeat step to remove the black wire to detach the wificard.
即将完成!
结论
2等其他人完成本指南。
