跳转到主内容
Samsung Chromebook Series 3 Speaker Replacement
你所需要的
  1. Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: 步骤 1 中的图像 1,3 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: 步骤 1 中的图像 2,3 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: 步骤 1 中的图像 3,3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Speaker Replacement: 步骤 2 中的图像 1,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 2 中的图像 2,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Speaker Replacement: 步骤 3 中的图像 1,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 3 中的图像 2,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 3 中的图像 3,3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Speaker Replacement: 步骤 4 中的图像 1,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 4 中的图像 2,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 4 中的图像 3,3
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Speaker Replacement, Battery: 步骤 5 中的图像 1,3 Samsung Chromebook Series 3 Speaker Replacement, Battery: 步骤 5 中的图像 2,3 Samsung Chromebook Series 3 Speaker Replacement, Battery: 步骤 5 中的图像 3,3
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Speaker Replacement: 步骤 6 中的图像 1,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 6 中的图像 2,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 6 中的图像 3,3
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Speaker Replacement: 步骤 7 中的图像 1,2 Samsung Chromebook Series 3 Speaker Replacement: 步骤 7 中的图像 2,2
    • You can now remove the battery.
  8. Samsung Chromebook Series 3 Speaker Replacement, Speaker: 步骤 8 中的图像 1,3 Samsung Chromebook Series 3 Speaker Replacement, Speaker: 步骤 8 中的图像 2,3 Samsung Chromebook Series 3 Speaker Replacement, Speaker: 步骤 8 中的图像 3,3
    • Disconnect the cable connecting the speakers to the motherboard by pulling on it away from the motherboard.
  9. Samsung Chromebook Series 3 Speaker Replacement: 步骤 9 中的图像 1,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 9 中的图像 2,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 9 中的图像 3,3
    • Lift up the piece of tape covering the trackpad ribbon cable.
    • Lift up the lock on the trackpad ribbon cable using a plastic opening tool.
    • Disconnect the trackpad ribbon cable by pulling it out.
  10. Samsung Chromebook Series 3 Speaker Replacement: 步骤 10 中的图像 1,2 Samsung Chromebook Series 3 Speaker Replacement: 步骤 10 中的图像 2,2
    • Lift up the trackpad ribbon cable so that it is not covering the speaker wire.
    • Lift up the two pieces of metallic tape so that they no longer cover the speaker wire.
    • When reassembling the device, make sure to lay down the metallic tape in the same place it was prior to disassembly. The tape serves as a connector for certain electrical circuits that should not be disconnected.
  11. Samsung Chromebook Series 3 Speaker Replacement: 步骤 11 中的图像 1,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 11 中的图像 2,3 Samsung Chromebook Series 3 Speaker Replacement: 步骤 11 中的图像 3,3
    • Unscrew the four 3.7 mm screws holding down the speakers using a Phillips #00 screwdriver.
  12. Samsung Chromebook Series 3 Speaker Replacement: 步骤 12 中的图像 1,2 Samsung Chromebook Series 3 Speaker Replacement: 步骤 12 中的图像 2,2
    • Pull the speakers up to remove them.
结论
7等其他人完成本指南。
Andrey Radchishin
于01/21/15注册
1,833 声望
创作了4篇指南
团队
UWT Liner: Group 1 UWT Liner: Group 1 的会员
Community
5 名成员
创作了8篇指南
一条评论
Many thanks.
Excellent guide .
Triumph Trident - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,573
