跳转到主内容
Samsung Chromebook Series 3 Motherboard Replacement
你所需要的
  1. Samsung Chromebook Series 3 Motherboard Replacement, Bottom Cover: 步骤 1 中的图像 1,3 Samsung Chromebook Series 3 Motherboard Replacement, Bottom Cover: 步骤 1 中的图像 2,3 Samsung Chromebook Series 3 Motherboard Replacement, Bottom Cover: 步骤 1 中的图像 3,3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Motherboard Replacement: 步骤 2 中的图像 1,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 2 中的图像 2,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Motherboard Replacement: 步骤 3 中的图像 1,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 3 中的图像 2,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Motherboard Replacement: 步骤 4 中的图像 1,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 4 中的图像 2,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Motherboard Replacement, Battery: 步骤 5 中的图像 1,3 Samsung Chromebook Series 3 Motherboard Replacement, Battery: 步骤 5 中的图像 2,3 Samsung Chromebook Series 3 Motherboard Replacement, Battery: 步骤 5 中的图像 3,3
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Motherboard Replacement: 步骤 6 中的图像 1,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 6 中的图像 2,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Motherboard Replacement: 步骤 7 中的图像 1,2 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 7 中的图像 2,2
    • You can now remove the battery.
  8. Samsung Chromebook Series 3 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,3 Samsung Chromebook Series 3 Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,3 Samsung Chromebook Series 3 Motherboard Replacement, Motherboard: 步骤 8 中的图像 3,3
    • Unscrew the four 3.1 mm screws holding the motherboard with a Phillips #00 screwdriver.
  9. Samsung Chromebook Series 3 Motherboard Replacement: 步骤 9 中的图像 1,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 9 中的图像 2,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 9 中的图像 3,3
    • The audio cable can be removed by simply pulling gently.
    • Use the iFixit opening tool to pop out the 2 antennae lines from the motherboard.
  10. Samsung Chromebook Series 3 Motherboard Replacement: 步骤 10 中的图像 1,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 10 中的图像 2,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Now, disconnect the keyboard and trackpad ribbon cables.
    • This requires lifting the lever securing the cables to free them, and then gently pulling them out.
  11. Samsung Chromebook Series 3 Motherboard Replacement: 步骤 11 中的图像 1,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 11 中的图像 2,3 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 11 中的图像 3,3
    • The screen cable is secure in place by a lever. Lift the lever to release it, then gently pull it out.
  12. Samsung Chromebook Series 3 Motherboard Replacement: 步骤 12 中的图像 1,1
    • This cable comes out by just pulling gently.
  13. Samsung Chromebook Series 3 Motherboard Replacement: 步骤 13 中的图像 1,2 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Lift the motherboard out of place and pull out the CMOS battery cable.
  14. Samsung Chromebook Series 3 Motherboard Replacement: 步骤 14 中的图像 1,2 Samsung Chromebook Series 3 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Finally, remove the three 3.1 mm screws with the Phillips #00 screwdriver to remove the plastic cover and completely free the motherboard.
结论
4等其他人完成本指南。
Tyler Schultz
于03/25/19注册
555 声望
创作了3篇指南
团队
IUPUI, Team S2-G1, Henning Spring 2019 IUPUI, Team S2-G1, Henning Spring 2019 的会员
IUPUI-HENNING-S19S2G1
3 名成员
创作了6篇指南
2条评论
Please tell me what i can do to put a cmos back from scratch i understand how to wire and tape the cmos and i see where to connect it but i dont have the connector and am wondering if i solder negative where positive should go by accident am i goin to fry the mother board?
MrAaron Camethesameasalametame - 回复
Why is it so important also what is the meaning of it? Like are these contraptions built with almost enough power but always need a tiny bit more or whats the deal with a cmos?
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 1,734
