跳转到主内容
Samsung Chromebook Series 3 Front Camera Replacement
你所需要的
  1. Samsung Chromebook Series 3 Front Camera Replacement, Screen: 步骤 1 中的图像 1,3 Samsung Chromebook Series 3 Front Camera Replacement, Screen: 步骤 1 中的图像 2,3 Samsung Chromebook Series 3 Front Camera Replacement, Screen: 步骤 1 中的图像 3,3
    • Use the iFixit opening tool to get under the front cover and pop it out of place
  2. Samsung Chromebook Series 3 Front Camera Replacement: 步骤 2 中的图像 1,3 Samsung Chromebook Series 3 Front Camera Replacement: 步骤 2 中的图像 2,3 Samsung Chromebook Series 3 Front Camera Replacement: 步骤 2 中的图像 3,3
    • Remove the four 2.9 mm screws with the Phillips #00 Screwdriver bit.
    • Using the iFixit opening tool, try to lift up the screen (it is held down by some adhesive).
  3. Samsung Chromebook Series 3 Front Camera Replacement: 步骤 3 中的图像 1,3 Samsung Chromebook Series 3 Front Camera Replacement: 步骤 3 中的图像 2,3 Samsung Chromebook Series 3 Front Camera Replacement: 步骤 3 中的图像 3,3
    • Lift the lever to release the cable and pull the cable out.
  4. Samsung Chromebook Series 3 Front Camera Replacement: 步骤 4 中的图像 1,1
    • You can now remove the screen.
  5. Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: 步骤 5 中的图像 1,3 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: 步骤 5 中的图像 2,3 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: 步骤 5 中的图像 3,3
    • Disconnect the ribbon cable connected to the front camera assembly.
    • You will need to flip up the little black lever to release the cable.
  6. Samsung Chromebook Series 3 Front Camera Replacement: 步骤 6 中的图像 1,2 Samsung Chromebook Series 3 Front Camera Replacement: 步骤 6 中的图像 2,2
    • Use an iFixit opening tool to pry the front camera assembly from the adhesive holding it in place.
结论
Tyler Schultz
于03/25/19注册
555 声望
创作了3篇指南
团队
IUPUI, Team S2-G1, Henning Spring 2019 IUPUI, Team S2-G1, Henning Spring 2019 的会员
IUPUI-HENNING-S19S2G1
3 名成员
创作了6篇指南
一条评论
Thanks for posting this! I looked all over youtube and couldn’t find anything so I am relieved to find this tutorial! I haven’t performed the repair yet, but I was wondering if removing the screen is necessary. From what I see, I can access the camera by just removing the bezel. Thanks for your feedback in advance!
Angel Knepper - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 419
