跳转到主内容
Samsung Chromebook Series 3 Charging Port Replacement
你所需要的
  1. Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: 步骤 1 中的图像 1,3 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: 步骤 1 中的图像 2,3 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: 步骤 1 中的图像 3,3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Charging Port Replacement: 步骤 2 中的图像 1,3 Samsung Chromebook Series 3 Charging Port Replacement: 步骤 2 中的图像 2,3 Samsung Chromebook Series 3 Charging Port Replacement: 步骤 2 中的图像 3,3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Charging Port Replacement: 步骤 3 中的图像 1,3 Samsung Chromebook Series 3 Charging Port Replacement: 步骤 3 中的图像 2,3 Samsung Chromebook Series 3 Charging Port Replacement: 步骤 3 中的图像 3,3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Charging Port Replacement: 步骤 4 中的图像 1,3 Samsung Chromebook Series 3 Charging Port Replacement: 步骤 4 中的图像 2,3 Samsung Chromebook Series 3 Charging Port Replacement: 步骤 4 中的图像 3,3
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: 步骤 5 中的图像 1,3 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: 步骤 5 中的图像 2,3 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: 步骤 5 中的图像 3,3
    • Unscrew the 3.4 mm screw holding down the charging port module using a Phillips #00 screwdriver.
  6. Samsung Chromebook Series 3 Charging Port Replacement: 步骤 6 中的图像 1,2 Samsung Chromebook Series 3 Charging Port Replacement: 步骤 6 中的图像 2,2
    • Remove the metal cover above the charging port module by pulling up and moving it slightly left.
  7. Samsung Chromebook Series 3 Charging Port Replacement: 步骤 7 中的图像 1,3 Samsung Chromebook Series 3 Charging Port Replacement: 步骤 7 中的图像 2,3 Samsung Chromebook Series 3 Charging Port Replacement: 步骤 7 中的图像 3,3
    • Pull out the charging port module connector by pulling directly up on it.
    • When reassembling, reconnect by positioning the connector directly above its original position and pushing down.
  8. Samsung Chromebook Series 3 Charging Port Replacement: 步骤 8 中的图像 1,2 Samsung Chromebook Series 3 Charging Port Replacement: 步骤 8 中的图像 2,2
    • You can now pull out the charging port module.
结论
10等其他人完成本指南。
Andrey Radchishin
于01/21/15注册
1,833 声望
创作了4篇指南
团队
UWT Liner: Group 1 UWT Liner: Group 1 的会员
Community
5 名成员
创作了8篇指南
2条评论
What is the reference number for this charging port?
How to find it on ebay/other?
rafal - 回复
If you search "Samsung Chromebook XE303C12" together with "Charge Port" or "Charging Port" or "DC Jack" you should be able to find it! :)
Andrey Radchishin -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 56
总计 17,458
