跳转到主内容
Samsung Chromebook 3 XE500C13-K05US Speaker Replacement
你所需要的
  1. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Place the Chromebook face down so the bottom case is uncovered.
    • Use the Phillips #00 screwdriver to remove all nine 4.6mm screws from the back case.
  2. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 2 中的图像 1,1
    • Use a nylon spudger or plastic opening tool to pry the case up from the vent on the hinge side of the Chromebook.
    • You will hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 3 中的图像 1,1
    • Raise the case up and off the device.
  4. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 4 中的图像 1,3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 4 中的图像 2,3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 4 中的图像 3,3
    • Disconnect the battery from the motherboard by prying upwards on the cable connector with a spudger.
  5. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 5 中的图像 1,3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 5 中的图像 2,3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 5 中的图像 3,3
    • Remove one 4.9mm silver screw from each speaker.
  6. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 6 中的图像 1,3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 6 中的图像 2,3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 6 中的图像 3,3
    • Use a spudger to gently push the cable connector sideways from the motherboard and the left speaker to disconnect the cable.
    • Remove the speaker.
  7. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 7 中的图像 1,2 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to gently push the cable connector sideways from the motherboard and the right speaker to disconnect the cable.
结论
Yamaris Acosta
于02/07/23注册
557 声望
创作了3篇指南
团队
Gateway, Team 4-4, Gonzalez Spring 2023 Gateway, Team 4-4, Gonzalez Spring 2023 的会员
GCC-GONZALEZ-S23S4G4
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 68
