跳转到主内容
Samsung Chromebook 3 XE500C13-K02US Speakers Replacement
你所需要的
  1. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Bottom Case: 步骤 1 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Bottom Case: 步骤 1 中的图像 2,2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: 步骤 2 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: 步骤 2 中的图像 2,2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: 步骤 3 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: 步骤 3 中的图像 2,2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Battery: 步骤 4 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: 步骤 5 中的图像 1,3 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: 步骤 5 中的图像 2,3 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: 步骤 5 中的图像 3,3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: 步骤 6 中的图像 1,1
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Speakers: 步骤 7 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Speakers: 步骤 7 中的图像 2,2
    • Remove two 4.9mm silver screws with a Phillips #00 screwdriver.
    • Each speaker only has 1 screw.
  8. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: 步骤 8 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: 步骤 8 中的图像 2,2
    • Use the spudger to pry the speaker connector sideways out out of the motherboard.
    • Repeat this step for the left speaker.
  9. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: 步骤 9 中的图像 1,1
    • Remove the speakers by lifting them upwards and out of the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 285
