跳转到主内容
Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement
你所需要的
  1. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Bottom Case: 步骤 1 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Bottom Case: 步骤 1 中的图像 2,2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 3 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Battery: 步骤 4 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 5 中的图像 1,3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 5 中的图像 2,3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 5 中的图像 3,3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement, Motherboard: 步骤 7 中的图像 3,3
    • Remove the three 4.6mm screws from the silver port cover using a Phillips #00 screwdriver.
    • The port cover will take a little wiggling to lift up and out of the laptop.
  8. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 8 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the right speaker connector using a spudger.
  9. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 9 中的图像 1,3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 9 中的图像 2,3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 9 中的图像 3,3
    • Use a spudger to lift the hinge locking the gold colored display cable in place.
    • Slide the hinge out to remove it from the motherboard.
  10. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 10 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 10 中的图像 2,2
    • Use a spudger to flip up the ZIF connector holding in the ribbon cable.
    • Once the ZIF connector has been lifted, slide the ribbon cable out of the motherboard.
  11. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 11 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 11 中的图像 2,2
    • Slide the track pad ribbon cable out from the motherboard using a spudger.
  12. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 12 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 12 中的图像 2,2
    • Lift the ZIF connector on the keyboard ribbon cable with a spudger.
    • Once the ZIF connector has been flipped, slide the ribbon cable out from the motherboard.
  13. Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 13 中的图像 1,3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 13 中的图像 2,3 Samsung Chromebook 3 XE500C13-K02US Motherboard Replacement: 步骤 13 中的图像 3,3
    • Use your Phillips #00 screwdriver to remove four 4.6mm screws from the motherboard.
    • Ensure there are no cables in the way and lift the motherboard up and out of the laptop.
结论
一条评论
Thanks for this. I was able to follow the steps and start up the Chromebook successfully. However, now my keyboard and mouse pad aren't working. I tried going back and reinserting the ribbon connectors a couple of times without success. If I plug in a separate mouse and keyboard, they both work. Anything else I should try?
Melissa Skilliter - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 1,119
