跳转到主内容
Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement
你所需要的
  1. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement, I/O Board with Integrated Wi-Fi Card: 步骤 1 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement, I/O Board with Integrated Wi-Fi Card: 步骤 1 中的图像 2,2
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 步骤 3 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver bracket.
  4. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 步骤 4 中的图像 1,1
    • Remove the silver bracket.
  5. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 步骤 5 中的图像 1,1
    • Remove the 4.6 mm screw from the I/O board.
  6. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 步骤 6 中的图像 1,1
    • Remove the wire connector from the I/O board.
  7. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 步骤 7 中的图像 1,1
    • Remove the black and white wires from the I/O board.
  8. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 步骤 8 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 步骤 8 中的图像 2,2
    • Lift the clip of the ribbon cable connector.
    • Remove the ribbon cable from the I/O board.
  9. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 步骤 9 中的图像 1,1
    • Lift and remove the I/O board from the base of the laptop
结论
Alex
于03/28/23注册
178 声望
撰写一个指南
团队
IUPUI, Team 3-3, Harley Spring 2023 IUPUI, Team 3-3, Harley Spring 2023 的会员
IUPUI-HARLEY-S23S3G3
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 139
