跳转到主内容
Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement
你所需要的
  1. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: 步骤 1 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: 步骤 1 中的图像 2,2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: 步骤 2 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: 步骤 2 中的图像 2,2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: 步骤 3 中的图像 1,2 Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: 步骤 3 中的图像 2,2
    • Remove the cover exposing the inside of the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 344
