跳转到主内容
Samsung Chromebook 3 Daughterboard Replacement
你所需要的
  1. Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: 步骤 1 中的图像 1,2 Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: 步骤 1 中的图像 2,2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Daughterboard Replacement: 步骤 2 中的图像 1,3 Samsung Chromebook 3 Daughterboard Replacement: 步骤 2 中的图像 2,3 Samsung Chromebook 3 Daughterboard Replacement: 步骤 2 中的图像 3,3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Daughterboard Replacement: 步骤 3 中的图像 1,1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Daughterboard Replacement, Battery: 步骤 4 中的图像 1,2 Samsung Chromebook 3 Daughterboard Replacement, Battery: 步骤 4 中的图像 2,2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Daughterboard Replacement: 步骤 5 中的图像 1,2 Samsung Chromebook 3 Daughterboard Replacement: 步骤 5 中的图像 2,2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Daughterboard Replacement: 步骤 6 中的图像 1,1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: 步骤 7 中的图像 1,2 Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: 步骤 7 中的图像 2,2
    • Before you begin the process of removing the daughterboard, you will need to remove the port case. Using a Phillips #00 screwdriver, remove the three 4.6mm screws.
  8. Samsung Chromebook 3 Daughterboard Replacement: 步骤 8 中的图像 1,2 Samsung Chromebook 3 Daughterboard Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to unhook the cable connecter from the speaker cable.
  9. Samsung Chromebook 3 Daughterboard Replacement: 步骤 9 中的图像 1,3 Samsung Chromebook 3 Daughterboard Replacement: 步骤 9 中的图像 2,3 Samsung Chromebook 3 Daughterboard Replacement: 步骤 9 中的图像 3,3
    • Pry the small coaxial cables upwards from the connecters on the wireless chip.
  10. Samsung Chromebook 3 Daughterboard Replacement: 步骤 10 中的图像 1,2 Samsung Chromebook 3 Daughterboard Replacement: 步骤 10 中的图像 2,2
    • Using the Phillips #00, unscrew one 4.6mm screw from the daughterboard.
  11. Samsung Chromebook 3 Daughterboard Replacement: 步骤 11 中的图像 1,3 Samsung Chromebook 3 Daughterboard Replacement: 步骤 11 中的图像 2,3 Samsung Chromebook 3 Daughterboard Replacement: 步骤 11 中的图像 3,3
    • Use a spudger to lift the gray plastic bar on the zif connecter up, then use your fingers to remove the cable ribbon.
  12. Samsung Chromebook 3 Daughterboard Replacement: 步骤 12 中的图像 1,1
    • Loosen the daughterboard from the USB port with a spudger as there is some adhesive underneath, and you're ready to remove the daughterboard.
结论
3等其他人完成本指南。
Sarah Westberg
于03/11/19注册
22,936 声望
创作了70篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,718篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 1,183
