跳转到主内容
Samsung Chromebook 2 XE503c12 Motherboard Replacement
你所需要的
  1. Samsung Chromebook 2 XE503c12 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Chromebook 2 XE503c12 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip device over so that the underside is facing up.
    • Remove nine, 7mm PH#0 screws from the bottom.
  2. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
    • Lift the panel out of the way to reveal the battery.
  3. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 3 中的图像 1,2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
  4. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift the battery, and pull it up and towards you, away from the connector.
    • Be sure to lift gently to avoid damage to connector
  5. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using a plastic opening tool, pry the connector up from the contact.
    • Remove the battery from the device.
  6. Samsung Chromebook 2 XE503c12 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 Samsung Chromebook 2 XE503c12 Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Locate the motherboard at top right of chromebook.
    • Remove four 9mm Phillips #0 screws and two 7mm Phillips #0 screws.
  7. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 7 中的图像 1,2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove auxiliary wires for microphone and webcam.
  8. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 8 中的图像 1,2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Lift hinge on connector up and pull the connector away from the device.
  9. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the connector for the motherboard and sub-board.
  10. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the connector for motherboard and chromebook.
  11. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the motherboard from the device.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 494
