跳转到主内容
Samsung Chromebook 2 XE503c12 Battery Replacement
你所需要的
  1. Samsung Chromebook 2 XE503c12 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Chromebook 2 XE503c12 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip device over so that the underside is facing up.
    • Remove nine, 7mm PH#0 screws from the bottom.
  2. Samsung Chromebook 2 XE503c12 Battery Replacement: 步骤 2 中的图像 1,2 Samsung Chromebook 2 XE503c12 Battery Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
    • Lift the panel out of the way to reveal the battery.
  3. Samsung Chromebook 2 XE503c12 Battery Replacement: 步骤 3 中的图像 1,2 Samsung Chromebook 2 XE503c12 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
  4. Samsung Chromebook 2 XE503c12 Battery Replacement: 步骤 4 中的图像 1,1
    • Lift the battery, and pull it up and towards you, away from the connector.
    • Be sure to lift gently to avoid damage to connector
  5. Samsung Chromebook 2 XE503c12 Battery Replacement: 步骤 5 中的图像 1,1
    • Using a plastic opening tool, pry the connector up from the contact.
    • Remove the battery from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 443
