跳转到主内容
Samsung Captivate Glide Speaker Replacement
你所需要的
  1. Samsung Captivate Glide Speaker Replacement, Motherboard: 步骤 1 中的图像 1,3 Samsung Captivate Glide Speaker Replacement, Motherboard: 步骤 1 中的图像 2,3 Samsung Captivate Glide Speaker Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide Speaker Replacement: 步骤 2 中的图像 1,2 Samsung Captivate Glide Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide Speaker Replacement: 步骤 3 中的图像 1,2 Samsung Captivate Glide Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide Speaker Replacement: 步骤 4 中的图像 1,3 Samsung Captivate Glide Speaker Replacement: 步骤 4 中的图像 2,3 Samsung Captivate Glide Speaker Replacement: 步骤 4 中的图像 3,3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide Speaker Replacement: 步骤 5 中的图像 1,2 Samsung Captivate Glide Speaker Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide Speaker Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide Speaker Replacement: 步骤 8 中的图像 1,2 Samsung Captivate Glide Speaker Replacement: 步骤 8 中的图像 2,2
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide Speaker Replacement, Speaker: 步骤 9 中的图像 1,1
    • Using the plastic opening tool, detach the tab connecting the speaker to the motherboard.
  10. Samsung Captivate Glide Speaker Replacement: 步骤 10 中的图像 1,1
    • Remove speaker manually.
    • There is nothing connecting it to the motherboard, so just pull.
结论
另外一个人完成了本指南。
Nicholas Mira
于09/23/14注册
289 声望
创作了2篇指南
团队
USF Tampa, Team 5-3, Mcgee Fall 2014 USF Tampa, Team 5-3, Mcgee Fall 2014 的会员
USFT-MCGEE-F14S5G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 432
