跳转到主内容
Samsung Captivate Glide QWERTY Keyboard Replacement
你所需要的
  1. Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 2 中的图像 1,2 Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 2 中的图像 2,2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 3 中的图像 1,2 Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 3 中的图像 2,2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 4 中的图像 1,3 Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 4 中的图像 2,3 Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 4 中的图像 3,3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 5 中的图像 1,2 Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 7 中的图像 1,1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 8 中的图像 1,2 Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 8 中的图像 2,2
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: 步骤 9 中的图像 1,2 Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: 步骤 9 中的图像 2,2
    • Remove the eight screws using the #00 screw driver.
  10. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 10 中的图像 1,2 Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    购买
  11. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 11 中的图像 1,1
    • Remove screws using the #00 screwdriver.
  12. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 12 中的图像 1,1
    • Using the plastic opening tool, remove the back plate by prying on the four main points.
    • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
  13. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 13 中的图像 1,1
    • Lift the back plate.
    • To remove the attached flex cable, gently peel the flex cable connecting to the back plate.
    • Flex cable is attached to the back plate with an adhesive.
  14. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 14 中的图像 1,3 Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 14 中的图像 2,3 Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 14 中的图像 3,3
    • Slide the flex cable through the slot.
    • Set the front plate down. Now you have free access to the keyboard.
  15. Samsung Captivate Glide QWERTY Keyboard Replacement: 步骤 15 中的图像 1,1
    • Manually lift the keyboard and replace with new keyboard.
    • Make sure the new keyboard is placed with the keyboard letters facing down, and the white back facing up.
结论
2等其他人完成本指南。
Jessica Martinez
于09/25/14注册
260 声望
创作了2篇指南
团队
USF Tampa, Team 5-3, Mcgee Fall 2014 USF Tampa, Team 5-3, Mcgee Fall 2014 的会员
USFT-MCGEE-F14S5G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 442
