简介
If you receive an error message when attempting to use your camera, and resetting to factory settings did not fix it, then you need to replace the camera or ensure that your camera is connected to the motherboard. At times, if you've dropped your phone, the camera may detach from the motherboard.
你所需要的
Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
即将完成!
结论
另外一个人完成了本指南。
