跳转到主内容
Samsung Captivate Earpiece Replacement
你所需要的
  1. Samsung Captivate Earpiece Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Earpiece Replacement: 步骤 2 中的图像 1,1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Earpiece Replacement: 步骤 3 中的图像 1,1
    • Replace the old battery with the new one.
  4. Samsung Captivate Earpiece Replacement, Rear Case: 步骤 4 中的图像 1,1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Earpiece Replacement: 步骤 5 中的图像 1,1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Earpiece Replacement: 步骤 6 中的图像 1,3 Samsung Captivate Earpiece Replacement: 步骤 6 中的图像 2,3 Samsung Captivate Earpiece Replacement: 步骤 6 中的图像 3,3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Earpiece Replacement: 步骤 7 中的图像 1,1
    • Separate the rear case from the phone.
  8. Samsung Captivate Earpiece Replacement, Antenna Cable: 步骤 8 中的图像 1,2 Samsung Captivate Earpiece Replacement, Antenna Cable: 步骤 8 中的图像 2,2
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
  9. Samsung Captivate Earpiece Replacement, Camera Assembly: 步骤 9 中的图像 1,1
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  10. Samsung Captivate Earpiece Replacement: 步骤 10 中的图像 1,1
    • Gently lift the camera assembly out of the plastic housing.
  11. Samsung Captivate Earpiece Replacement, Motherboard: 步骤 11 中的图像 1,3 Samsung Captivate Earpiece Replacement, Motherboard: 步骤 11 中的图像 2,3 Samsung Captivate Earpiece Replacement, Motherboard: 步骤 11 中的图像 3,3
    • Using the spudger slide the tool under the three highlighted connectors to begin disconnection
    • Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
    • Be careful to not pry against the connector. Prying against could further damage to the device.
  12. Samsung Captivate Earpiece Replacement: 步骤 12 中的图像 1,1
    • Use your fingers to carefully lift up the Samsung Capivate's Motherboard from the assembly.
  13. Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: 步骤 13 中的图像 1,2 Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: 步骤 13 中的图像 2,2
    • Gently pull up on the audio jack, taking the attached ribbon cable with it.
    • There is a small amount of glue holding the ribbon cable that attaches the audio jack to the earpiece.
  14. Samsung Captivate Earpiece Replacement, Earpiece: 步骤 14 中的图像 1,1
    • The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
结论
2等其他人完成本指南。
Drew Bentz
于09/22/11注册
565 声望
创作了5篇指南
团队
Cal Poly, Team 20-25, Maness Fall 2011 Cal Poly, Team 20-25, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G25
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 2,379
