简介
The camera assembly is susceptible to various environmental forces such as moisture, vibration, and shock. Replacing this part is easy.
你所需要的
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
3等其他人完成本指南。
2条评论
Is this for the front facing camera
tracy mann - 回复
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
